Hauling ?
JD B Bob
09-12-2000 07:16:24
I just bought a B and have not hauled any narrow fronts befor. Any suggestions on tie down points? I have Straps with D rings and chains etc. Just wonder about the front tie down. Thanks, B Bob
Ray
09-12-2000 18:46:15
 Re: Hauling ? in reply to JD B Bob, 09-12-2000 07:16:24
Hauled hundreds of old tractors.All you need is
2 chains,one on each rear wheel.Utility tractors,
one chain across center.It's funny at some of these shows,you see city slickers with 4 chains
on an 8N ford.
B Bob
09-12-2000 14:48:13
Thanks again, will have to pick up some smaller ones tomorrow. Will be driving down and back tomorrow night. Cant wait to get it home. I got a lead on an A today, --Maybe-- Bob
John T
09-12-2000 08:54:46
Bob, heres how I haul my B. I use four point chains (all about 45 degrees like an X to the
tractor) \_____/ that each pull in equal but / \
opposite directions, two front and 2 back. On the front on the frame rails just behind the radiator, I have two clevises that go through frame rail holes one on each side. I use two rear chains each hooked to a clevis on the drawbar. That way its stretched front and back and side to side all at 45 degrees and I set the brakes and have it in low gear. I prefer chains because the air in the tires provides enough stretch without any added stretch of straps. Put about 10 to 15 percent of the trailer and tractor weight on the tow vehicles tongue weight. John "T" Nordhoff
B Bob
09-12-2000 10:57:12
 Re: Re: Hauling ? in reply to John T, 09-12-2000 08:54:46
Thanks John, the part about the clevis in the front frame is the magic for me. I have hauled a fair amount, just no narrow fronts and did not want to hook to the wrong part. I will take a couple clevis's along. Can you tell me off the top what size hole that is? I wont see the tractor till I make the trip to haul it back. I think I have 1/2 and 5/8 pins on the clevis's I have now.
John T
09-12-2000 11:25:33
 Re: Re: Re: Hauling ? in reply to B Bob, 09-12-2000 10:57:12
Bob, on my unstyled 38B the holes in the front bottom of the frame are only like 1/2 to 5/8 inch in which I put the small horseshoe shaped clevises with screw in type pins. I have short chain sections through the clevises with slip hooks on the ends that I attach my chains too so I dotn scratch the tractor. John T
