JD 40 question on transmitions fluids/hydralic fluid
glenn
09-09-2000 13:45:16
I need to drain and replace my trans fluid
I have a manual but it doesnt tell me if the trans fluid and rear differential share the same fluid?. Does the hyddralics also use the same fluid??what is a good replacement fluid?
would a multpurpose hydralic/trans fluid work in all of these systems? thanks in advance.
Glen M Taylor
09-10-2000 09:54:16
 Re: JD 40 question on transmitions fluids/hydralic fluid in reply to glenn, 09-09-2000 13:45:16
Don't forget the final drives. They don't drain and fill with the transmission. The fragile Ring & Pinion will be better protected with a 140 weight synthetic. Will the tractor be used? For parades and hayrides GL5 140 mineral oil will do OK. Who published your manual? Often find those IT manuals somewhat lacking.
Johnnyputt
09-09-2000 17:51:44
Transmission and differential needs 90W. I use 85W90....easier to find and cheaper.
The hydraulic system uses 10W. Years ago they would add some non-detergent 30W also.
