630 hyd.pump
Rich Griffin
10-13-2003 18:45:38
This tractor came to the shop with a scored shaft in the pump. Does anyone know how this shaft gets lubricated other than by splash system? It is running good oil pressure. Thanks for any help.
MIKE HANLEY
10-13-2003 22:13:49
 Re: 630 hyd.pump in reply to Rich Griffin, 10-13-2003 18:45:38
We had problems with our 630 pump. The end of the shaft on the governor that drives the gear that drives the pump A5696R was wearing in to the end of the casting cover A 5697R and we were snapping the long shaft in the pump F2734R in two right at the place where it has the slit is cut into the shaft. (I can not figure out why that slit is cut into the shaft.) We ended up haveing the casting machined out and bushed back to fit a new shaft. At the same time I had the machine shop drill and tap in to the casting for a oil fitting. I then TEEed into the oil line going to the fuel shut off. Have not had any problems since. That way we are shooting oil on to the governor drive gear A5698R which throws oil up to the gears in the pump AA5192R. When putting the pump back on it's not easy to prime the pump as it is higher then the tank. To prime the pump I raise the 3PT arms with a high lift jack and after filling the tank, lower the 3 pt and that shoots oil into the pump. I'm guessing that was 10 years or so ago that we did that. Our pump is getting weak so I'm planning on taking that in and have the faceings shaved. We did this to the pump on the 730D two years ago and the pressure went from 800 PSI tp 1400 PSI
