JD 50 conversion from cast to pressed steel?
Sid Thompson
09-03-2000 07:31:52
Would it be possible to convert the cast wheels to pressed steel wheels? Has anyone done this? This is an excellent pulling tractor in the 5500lb class but would like to get to 4000 or 4500 not much left to do after you take off powertroll any Ideas? Thanks Sid in Colo
Mike
09-04-2000 00:42:35
 Re: JD 50 conversion from cast to pressed steel? in reply to Sid Thompson, 09-03-2000 07:31:52
I made a set of adapter plates so I could run 9 bolts on my G. The plate bolts to the existing hub.They are made out of 3/4 " flat stock. Mike
Mike Aylward
09-03-2000 16:21:33
Sid, I think there is a way to do this, but it will take a little effort and luck on your part. The axle size on a 50 is 2 7/8". If you can find some, get some factory dual hubs for a 4010 with the 3 1/8" axles and remove the wheel wedges and put the ones in out of your cast wheels. Then you can bolt on a set of nine bolt wheels. Do not get a set of hubs for a 4020 (3 3/8") as the taper of the wedges is different. With this setup you will likely lose somewhere in the neighborhood of 250- 300 lbs. or so. Hope this helps. Mike
