JD torque Specs
Zane
09-02-2000 08:34:39
Been told tractor is 3020 JD. Fact on plate on rear end Model T713R Serial 018374R Plate on side of engine Motor M53RC Serial 138010.
Need torque specs on head bolts, connecting rod bolts, and main brgings.
Thank-you
G Taylor
09-03-2000 13:29:49
 Re: JD torque Specs in reply to Zane, 09-02-2000 08:34:39
This site has service manuals avalable or call Deere at 1-800-522-7448. You can't overhaul a tractor with by guess and by golly on component clearances, assembly proceedures and torque values. Manuals cost less than the gasket set to do the job over again.
G Taylor
09-03-2000 13:29:40
Zane
09-02-2000 09:14:54
It is JD 2520. It has the hydraulic on a console at the right side of the seat. alternator and 12 volt system. Injector pump is on left side of enging laying down. The balancer system is not bolted to the middle of the engine under the crank. It is two shafts down each side of the engine
