John Deere H
fuel to be used
Wm. D. Elliott
09-02-2000 06:47:37
I'm considering purchasing a JD "H" to restore, but do not understand the fuel to be used. Is diesel or gasoline to be used? If not, then what? I have seen references to distillate, but what is that and where do you get it?
Thanks.
Paul {The Kid}
11-18-2004 22:38:59
 Re: John Deere H - fuel to be used in reply to Wm. D. Elliott, 09-02-2000 06:47:37
The smaller tank almost a gallon was used to get the "H" running on gas then when she warmed up to about 160 degrees it was switched over to farm fuel which was like kerosene which has a little diffenert sound on the Johnny Popper.
Stan
09-02-2000 17:13:10
Yep, gasoline will work fine. I've heard rumors that if you use unleaded gasoline under a heavy load it will cause valve burning problems. I can't prove that one way or another.
Having grown up on a B that started on Gas and ran on distillate (a lot like kerosene) I think the H will work fine on gas. Just don't put it under a heavy load all day.
Stan
Frank
09-02-2000 12:20:18
Use gasoline. You'll notice it has two fuel tanks. They were made to start on gas then, after it warmed up, switch to distillate, I've been told, distillate is similar to kerosene. Anyway you will be just fine running it on gas all the time.
