H carb problem
Mark Scholten
10-13-2003 18:32:21
1st off I want to thank Paul from Mi for the info on the hydraulics for my styled D. Polks has them for $475.00. My question concerns my H. It isn't getting any fuel through the carb. The bowl is full, the needle and seat is fine and when I hook a belt from another tractor, It runs fine pouring gas into the carb. I don't have the air cleaner hooked up but this shouldn't make any difference. I have soaked the carb, blew all the passages out with compressed air, no good. Carbs aren't that complicated, or at least they didn't used to be.
Suggestions are begged for, solutions a must.
Thanks, Mark in Sparta, Michigan
Clooney
10-14-2003 03:14:58
 Re: H carb problem in reply to Mark Scholten, 10-13-2003 18:32:21
Mark, those DLTX 26/46 carbs are a little more complicated than they look. There are hidden passages & transfer holes that aren't shown in most online views. On the other hand they aren't rocket science either.
~If you send me your E-Mail address I will send you a carb diagram showing the holes & passages that need attention.
~You will probably need to run small wires down the passages & holes as just blowing air & solvent through them usually won't get the job done.
[email protected]
