Best quick detach loader for a 4230
Westy
08-30-2000 03:40:18
Is there a good quick detach loader for a 4230 out there?
Wm. D. Elliott
09-02-2000 06:56:43
 Re: best quick detach loader for a 4230 in reply to Westy, 08-30-2000 03:40:18
I own a 4230, but do not have a loader for it. What would you suggest is the optimum loader for the 4230? Does JD sell new ones? Do you recommend a used one, if it can be found?
Thanks.
Westy
09-03-2000 22:24:44
 Re: Re: best quick detach loader for a 4230 in reply to Wm. D. Elliott, 09-02-2000 06:56:43
I have talked to a friend who has a 4230 with a Westondorf loader on it. It looks real strong and comes off with just 2 little latches and then the hydraulic lines. Also, I hear the JD 720 is a good heavy duty loader but you may pay 500 to 1000 more for it. Make sure that if you are looking at a quick detach that it has its own feet to stand upright on its own and that you do not have to pay extra for it. You need 2 remotes off of the 4230 or other hyd source to run the loader
Duke
08-30-2000 19:46:47
If you can afford one the new 720 from deere is a great loader. It has been built for a few years so you may find a used one. It comes with parking stands and detaches by pulling two pins.
