John Deere 50 Roll a Matic
Jack
08-29-2000 08:56:48
I have just purchased a JD model 50 and the roll a matic front end is shot. Can it be repaired or should I find another unit to replace it.
Chuck
08-30-2000 05:14:00
 Re: John Deere 50 Roll a Matic in reply to Jack, 08-29-2000 08:56:48
I have a unit off a late model B, would have to cross reference part #'s to see if same...would be willing to sell at a reasonable price, lot cheaper than salvage yards....you can email me personally...need to check with dealer and see if parts are same.
Fudd
08-29-2000 19:53:42
Call Ron Stephans at 319-822-7348, he might have a used one. Good luck.
Fudd
08-29-2000 19:55:12
 Re: Re: John Deere 50 Roll a Matic in reply to Fudd, 08-29-2000 19:53:42
Did you put your 50 in the registery? Mine is a 53, what year is yours?
Ron
08-29-2000 13:13:51
Exactly what is "shot"? I checked a couple years ago and the two arms were still available from Deere at about $600 each. I would expect that any you might find in a salvage yard would be "shot" too. Mine are worn, but not bad enough to justify $1200 in repair cost. I didn't spend that much for the entire tractor!
Paul
08-30-2000 20:08:07
 Re: Re: John Deere 50 Roll a Matic in reply to Ron, 08-29-2000 13:13:51
I replaced a bent arm on my 50 with one from a "B" and it fit perfectly. I can't remember if the part numbers matched, but I assume they did. $20 for the arm from a local "fence row" tractor.
