John Deere H
Removing the Hood
Don
08-29-2000 04:38:34
When I tried to remove the hood of my H, it appeared that it is bolted down at the gas tank support brackets and that even though removal of the steering shaft, etc. was easy, getting to the gas tank bolts made the job much more difficult. Is there a 'quick and easy' way to remove the H hood or must I try to reach the gas tank bolts?
HMan
08-29-2000 19:09:03
 Re: John Deere H - Removing the Hood in reply to Don, 08-29-2000 04:38:34
Will is correct, leave the tank bolted to the hood. Take it loose at the 2 support bolts and pull tank and hood as one piece. HMan
WILL
08-29-2000 08:01:43
I ALWAYS JUST REMOVE THE ONES ON THE BLOCK.THAT WAY WHEN YOU SET IT DOWN ON TABLE OR FLOOR THE BRACKET WILL HOLD IT UP AND THE SEDIMENT BULB WILL BE OK.
