Inherited two old A's...
Baggsy
08-28-2000 13:20:08
I just found out I'm the proud inherit'er (?) of two old JD a's. One's an unstyled '36 and the other is a styled '40. Both are stuck with poor rubber and the jealous brother-in-law has taken some parts off already. I was gonna move 'em this weekend, shoot some pb-blaster in the spark plug holes and fill the crankcase with diesel. I've never done an old two cylinder, and was wondering if there's something else I should do. I'm just finishing up an old Case in the garage, so these will be my next project. If I can get 'em restored I'm betting my wife will even be proud of me, as these were her dads...
Tom
08-31-2000 14:04:04
 Re: Inherited two old A's... in reply to Baggsy, 08-28-2000 13:20:08
Sounds like a lot of work and money for nothing.
Maybe that's the reason he didn't restore them,
he knew they were not worth it.The best you can do is loose money.
Wind
09-01-2000 13:05:35
 Re: Re: Inherited two old A's... in reply to Tom, 08-31-2000 14:04:04
Can't be that bad of a money loser, he inherited them. And how much is sentiment worth?
Rollo Ingram
08-29-2000 04:27:11
Open the compression release valves on the bottom of the block and see if the cylinders are full of water. Mine were. I don't know what pb-blaster is, but it's hard to compress water.
L.C.
08-30-2000 20:26:34
 Re: Re: Inherited two old A's... in reply to Rollo Ingram, 08-29-2000 04:27:11
PB-Blaster is an aerosol penetrant. Works pretty well.
Good luck on the As.
john
08-29-2000 05:23:56
On the models mentioned the compresson release is on the side of the block, just above the frame.
Gary Warfield
08-28-2000 19:17:43
Baggsy,
You have inherited two fine pieces. It sounds to me (though I am no expert) that you are on the right track. My only advice to you is to keep your #*&%##& brother-in-law away from your tractors!
