Another first for me!
DP
08-27-2000 14:59:35
Some of you may have run into this. My 49 A would start and run fine. After a little while it would die just like I shut the switch off. It has a Wico XD distributor on it. I put a new condenser in it with no change.After some checking, I found the balast resistor wire had some coating missing from the wires, was shorting out, and and was throwing a full 12 volts to the coil. After a little bit the coil would fail and shut the tractor off. That resistor is no longer available, so I bought an external resistor and rewired the distributer. No more shuting down. I hope this saves some of you fellows grief if this problem arrises for you.
