Another Bridgeport Mill Question Sorry
Paul
11-10-2003 16:57:03
I went and looked at the mill today. it is variable speed and has Servo power feed both ways on the table. it also has a servo motor on top the spindle and according to the salesman it is for locking the collet. It also has accurite digital readout X and Y. It has a large vise and he will throw in a set of collets and wants 4200.00. the machine is late 70's or 1980. He told me he put 100lbs of weight on the end of the table and moved the table all the way to the end and it was 10 thousands different which he said was not bad at all. The feathering that is machined on the flat ways look almost the same all the way down. the salesman said it was original. I ran my finger across the feathering and it felt slightly rough. Is this normal or could someone have redone it. sorry for the long post but I'm not familiar with these and I dont want to get burnt. He will gaurentee it for 30 days and from what others say he has a good reputation. the business is only 20 miles from me. thanks Paul
Kent of SW MO
11-11-2003 11:19:54
 Re: Another Bridgeport Mill Question Sorry in reply to Paul, 11-10-2003 16:57:03
$4200 with vice. vary speed and digita; readout, Sounds like a deal, BUY BUY BUY.
Wolfie
11-11-2003 10:50:12
I have been a tool room machinist for over 30 years and have used Bridgeport mills and Bridgeport cnc machines. I also have used an Enco look a like. Now here is the difference the Bridgeports were used day in and day out the machines needed very little maintance. The Enco was bought new and was shot long before any Bridgeport died. The Bridgeports are still there after I retired but the Enco is gone. But dont get me wrong if some hot shot run's the Bridgport like there is no tomorrow then it will not be worth a dime . Beleave me we had a few of those guys that had to show the boss look here I did this in only a day. Now look at the table see if there are a lot of deep nicks . If there are that means a lot of heavy work was on the table. Look to see if there are a lot of drill holes on the table again if there are that means the worker did not care to make sure he or she drills into the job and not the table. Lisen to the spindle run If it clatters a lot the brearings could be shot. Not cheep to fix. Also run the varible speed up and down make sure it goes the full range. Put the machine in back gear to make sure the back gears still work. Also crank the table up and down to check for excess slop. Crank the table back an forth and read the dial for back lash a good machine will have very little back lash in the screws. Now you say you are geting a air collet closer, a set of collet's make sure it is a complete set. Collet's can cost a few bucks if you want good ones. You said a vice come's with the machine. Again a cheep vise is just that cheep. If it can't hold the part you are maching in place throw it a way. A Kurt vice is one of the best. Check the power feed by runing the table back and forth. Make sure the table feed dial works so you can adjust your work feed. The power feeds tend to wear with time. Again it can cost a few bucks to fix. The options you listed are nice. But mean a lot less if they have to repaired or are a cheep grade. I hope this helps you. Again look at the machine. If it shows a lot of abuse stay away. You can buy a brand new Jet mill for about the same money maybe even less. For light work The Jet will last you a long time. Also comes with a waranty. The place I work at now bought a Brand New 14 inch gear head Jet lathe with all the options. A Set of new Royal collet's At 1/64ths also sqare and hex collets A Jorgen collet chuck, a new 3jaw and 4 jaw chuck. Also had a new Topaz readout installed. We even bought an Aloris quick change tooling system . All for under 12,000. But a again this machine is used on plastic and Alum. no hard machining been using it for 5yrs had no problem except stop switch fixed under the waranty. The Jet mill might just be an option for you.
Wolfie
SamH
11-11-2003 06:34:06
Paul, I don't know what your use for a Bridgeport is, but for $4200, I would expect a pretty good machine. It is good that you are dealing with a reputable salesman. That always helps.
Flaking/scraping serves 2 purposes. >As has already been stated, it allows lube oil to get to the ways
>It is one of the most accurate ways to create a flat surface. An expert can make the Bridgeport better than new, but its not always the expert who rebuilds them.
The two areas that wear are the lead screw and the ways. The most severe wear on Bridgeports is usually in a zone of a few inches on either side of center. That's because most workpieces are not big enough to require the full table travel, so they are set up near center and the table is only moved a few inches in either direction. Lathes and most other machine tools have this kind of wear zone.
There are ways to do some precision accuracy checks that I don't have room to get into here, but there are some down and dirty stuff you can do with only a dial indicator. Why don't you ask the salesman to let you do the following--
>With the table at about center, put a dial indicator either in the spindle or on a stand and set it against either table end. Push and pull the table from side to side and see what kind of movement you have. Now do the same at the other end and also in the middle. >Run the table end to end with the indicator against the table. Now do it in the other direction. Watch the indicator to see if the table shifts when you change directions. While you are doing this, you can also look for indicator motion that could mean the lead screw is bent. >To find out if "X" and "Y" are perpendicular, use a magnetic block or clamp to fasten a square block or maybe a combination square onto the table. Indicate it parallel to the table in one direction and then see what happens when you crank in the other direction.
I suggest you perform the movements using both the power feeds and by hand cranking just to see if that turns out differently. You can tell a lot by the way a machine feels.
I hope this helps.
Donny-B
11-10-2003 19:36:13
Paul, The way "Flaking" will have a bumpy feel to it. It provides little pockets where oil is contained to "float" the table. If the flaking is uniform across the entire way surface, it probably had light use or was re-scraped and flaked at one time. I dont quite understand what the dealer was testing by putting 100# of weight on the table or how he indicated a .010 difference from one end to the other. If the mill has DRO, a Servo power feed, power drawbar, vise & collets, it sounds like a fair deal. I still would have to hear it run in both hi and backgears reguardless what the dealer guarentees. A sloppy drive spline or worn spindle bearings would lessen the value by 1/2. Good luck.
F-I-T
11-10-2003 17:06:49
Paul:
You asked:
"The feathering that is machined on the flat ways look almost the same all the way down. the salesman said it was original. I ran my finger across the feathering and it felt slightly rough. Is this normal or could someone have redone it."
On the Bridgeports I have used/owned/torn down, the ways have that erractic scraping track from the factory. I think if they were solid surfaced, they tended to wring together with a bit of oil and could get pretty sticky. It also was an area where minute debris could get out of the way of the action.
The only way to tell if it has been re-scraped would be to look it over closely and see if you can see an old versus a newer scraped surface. Even so, I would not think a good job of scraping would detract from the overall expected performance of the mill.
Frank
Steve Crum
11-11-2003 07:00:49
 Re: Re: Another Bridgeport Mill Question Sorry in reply to F-I-T, 11-10-2003 17:06:49
My wife's Uncle put a lot of this into perspective for me once. He was an engineer for a major glass manufacturer until he retired, and spent half his career in China. Brokers in America working on behalf of Chinese companies buy up every American made machine tool that they can that can carry a tolerance in a basket at a reasonable price. The tool is shipped to China and sold. These are then used to manufacture the spiffy new Enco or any other of hundreds of name machine tools. The ironic part of this is the person that ultimately operates the machine quickly becomes familiar with the shortcomings of the machine and is very particular to monitior quality to overcome these short comings. A little more time can be allowed for this as after all what do these people earn an hour? Hence you have a new machine that carries respectable tolerances for less than a fair used American made machine. Theres nothing illegal or unethical about this. You have two comparable cars sitting on a lot one used, one new.
The used one is a quality name plate that shows some signs of use, but none the less is right up there with the brand new off name import sitting next to it that sports the same toys and apparent quality. Price of the used one is at the high end of reasonable, and new one is the same price or less. Pretty amazing that someone in China can be living the American dream.
It's saddening to hear people at a large local tool manufactuer threaten to go on strike because they cannot"live" on $16.00 an hour plus another 7 or 8 bucks an hour in benefits and occasionally have to work overtime.
Denny Foster
11-11-2003 18:53:22
 Re: Re: Re: Another Bridgeport Mill Question Sorry in reply to Steve Crum, 11-11-2003 07:00:49
Is this a Bridgeport M head or J head machine??
