G Puller
Duben
08-23-2000 19:30:40
I have a 47 GW that I would like to pull. It's been used as a farm tractor for the last 25 years (just was replaced with a 4020) with no special work done to it. I don't think I can get it under the 6,000# class break unless I change to a narrow front (which I don't want to do). Don't see any GW's pulling here (west coast). Appreciate any ideas to make it competitive but still usable for mowing, etc.
G Taylor
08-24-2000 20:49:50
 Re: G Puller in reply to Duben, 08-23-2000 19:30:40
There are companies in Green Mag who make a custom head, intake and carb. Then you can set the origionals aside for storage. A reground cam and high compression aluminium pistons. Don't try it without rebalancing the bottom end. Set the restrictive oil bath air cleaner on the shelf as well. A K&N or Amsoil low restrictition air filter is the cheapest HP per dollar modification. With the fast 1st gear and tall 38' tires a stock G can be stalled on a sticky track even in the light classes. 55 belt HP is the minimum with 15.5x38 tires in the 6500 lb class.
Gman
08-24-2000 10:02:54
Duben what is the serial# of your tractor,there were only a few GW's made between 23,000 and 26,000 which is I think your tractor is in this range,and they are rather collectible so be careful of modifications,I would retain the cast Iron pistons and make a smooth running farm and show tractor. Drop us an email on the serial #. Gman
Mike
08-24-2000 04:29:03
I went to a stone boat pull last night w/ my G. There were 60 + tractors there. Myself and a JD D were the only gas tractors left running when got to 9000# of block. We did beat a couple of 720 D's. But for the most part once the 720D's , the 820D's and one 830D came out we were all done. I pull Friday for the first time on a transfer sled so I will post how I do . Mike
Duben
08-24-2000 21:00:29
 Re: Re: G Puller in reply to Mike, 08-24-2000 04:29:03
Out here we use weight transfer machines and are placed by 1000# classes (6,000 to 7,000 for example). I also own a 730 Diesel that I pull but the G is no match for the 730. The G weighs 6,400# and my 730 weighs 8,800# with fenders, 3 point and 500# of front weights. Good luck on your next pull!
