Jumping 6 volt system
AS
08-21-2000 05:50:50
I have a B with a 6 volt system. Right now I have no battery, no generator or wiring. Can I jump the starter with a 12 volt battery without hurting anything? I've never used the starter, so i'm not even sure it works. Thanks.
John T (Sure)
08-21-2000 07:18:04
 Re: Jumping 6 volt system in reply to AS, 08-21-2000 05:50:50
AS, if you have no battery or generator or wiring as you say, sure you can jump just the starter with 12 volts and she should really spin fast but avoid long cranking periods. If you ever want to do the same with a bunch of other stuff connected, however, you better post back for more precaution warnings. Ol John T in Indiana
Keddano
08-23-2000 20:49:49
 Re: Re: Jumping 6 volt system in reply to John T (Sure), 08-21-2000 07:18:04
John,I've wondered about that,as there has been times with a dead 6 volt battery and a need to start the tractor quick.What's the best way,disconnect battery,then jump?,Thanks Dan
G Taylor a hurry is no reason to take risks
08-24-2000 21:02:50
 Re: Re: Re: Jumping 6 volt system in reply to Keddano, 08-23-2000 20:49:49
No tractor has to be started urgently enough to risk a face full of acid. See Old Elec Engineer's post for details. Too many people have wrecked equipment,them selves, bystanders or their children who learn to take unsafe shortcuts. Almost every rural mess the local fire department and ambulance have to clean up and explain to the family involved a shortcut. Ever see the wreckage of a person after a few turns around a PTO shaft or pinned under a rollover etc ?
