John Deere 730
Mike Quale
08-20-2000 21:28:04
I have started to tractor pulling with my 730 gas and I was wondering what is the best size tire to run with...I have 15.5X38's on there now. and I was wondering how larger tires will affect my gearing....I have a creeper gear in 1st so I pull in second...but I run out of power then, I lose traction if I run in 1st...I was wondering if larger tires would act as a faster creeper gear so I could have power but not lose traction .... Thanks in advance everyone
Greg H.
08-21-2000 13:41:59
 Re: John Deere 730 in reply to Mike Quale, 08-20-2000 21:28:04
if you are pulling antique class try 14.9's, if you can find them. If you are just talking about a regular farm pull, try 18.4 x 38. With your creeper gear, you should be able to pull first and maintain adequate power. I know two gentlemen who do this with their 730's and one with a 720, and if the track is sticky they do very well, and seldom ever power out. Just load the nose heavy so you have steering past 200, and let the sled give you back weight, and steer around the holes and you should do fine. if you've got a 730 you've got a good tractor. Greg H.
BigJ
08-21-2000 07:55:08
Try some 14.9's on it,they are a little taller.
