4010 Power Steering
Roger K. Tate
08-19-2000 18:49:30
Something wrong with the power steering -- turns left fine but turns very hard to the right. Cannot see anything visually wrong outside the tractor. Any ideas? Thank you.
twopop
08-20-2000 15:28:10
 Re: 4010 Power Steering in reply to Roger K. Tate, 08-19-2000 18:49:30
the front axle should be raised of the ground and make sure it turns freely.one of the spindles could be bad,but not likely with what you describe.the problem is probably in the steering pump under the dash.you will need to take it out and let jd repair it
