Fuel pump problems on JD 317 (Kohler twin 17hp)
John Elk
08-19-2000 13:40:09
My fuel pump is not pumping fuel. I took off the top and was unable to see anything wrong with the mechanism or operation, but no suction in or push out at all. Could be the diaphram is fatigued after 20 years of use. Does anyone out there have any information, maybe a schematic they could send me, on that fuel pump. Viewed from the top, it is about 2 x 2 inches and square. Can this pump be rebuilt, and how do I get it off the engine? Any help at all would be appreciated.
Wayne Swenson
08-20-2000 22:07:05
 Re: fuel pump problems on JD 317 (Kohler twin 17hp) in reply to John Elk, 08-19-2000 13:40:09
I have replaced mine on my 317. It is an easy task. Remove the air cleaner, unhook the fuel lines, carefully blow all debris away, and remove 2 hold-down bolts. The pump is not rebuildable. See your Kohler dealer or your favorite John Deere dealer. cost about $25-$30.
Be sure to carefully re-attach the fuel lines and check your fuel filter. You may wish to put one in the supply line from tank to pump if none is present.
John Elk
08-21-2000 23:38:12
 Re: Re: fuel pump problems on JD 317 (Kohler twin 17hp) in reply to Wayne Swenson, 08-20-2000 22:07:05
Thanks, Wayne. Do you or anyone else have a source for that pump? The cheapest I could find it for was $45 at a John Deere Deale
John Elk
08-21-2000 23:36:08
I couldn't find anyone selling that fuel pump for less than $45. Do you have a less expensive source? By the way, thanks for your advice, Way
