60 help....
Kevin
11-10-2003 14:58:06
Ok this a dumb question but I can't figure it out.
I just got a 53 Model 60. I want to check the oil level then change it. The problem is I can't figure out how....From what I read about Model A's there is a valve and when it flows out its full. I can't find a valve and I'm not sure I have the right fill cap. The one I found(fill cap) is good size 2"or 2 1/2" and looks like the cap for my oil tank on my house, is this the right one? I ordered a manual to help the problem but the dealer told me it could take 3 weeks....I don't want to run it without checking the level and I want to change it but run it first. I think I know the location of the drain plug and filter cap but thats it. Any help would be appreciated I want to show everyone the sound and why I bought it. Thanks for your help, Kevin
Kevin
11-10-2003 17:20:59
 Re: 60 help.... in reply to Kevin, 11-10-2003 14:58:06
Thanks very much for the help and the diagram.....
Ron
11-10-2003 16:59:23
Yes, it is under the CLUTCH Drum....be sure to unscrew it far enough to let the oil run out-- maybe 3 full turns...!! Unscrew only the end ...!!!
Steve - IN
11-10-2003 16:51:26
third party image
Kevin,
Here's a photo posted in the parts and pieces gallery here from FIT that shows the parts manual drawing of the plug you use to check it.
If the drawing doesn't make immediate sense, look at the center of the clutch cover -- move your eye to about the 4 o'clock position on the cast case, and you should see a fitting with a bolt stuck in it. Unscrew it -- if oil runs out, you're OK. If not, fill it until it does through that big thing that looks like the filler cap for your house oil tank.
old
11-10-2003 15:33:01
If it has a oil check plug it should be behind and just under the flywheel on the front side of it. Also from what you say the other thing is your oil fill place, on my B its under the steering wheel in front of the seat and sticks up about 12 inches. Hope this helps
