730 steering problems
plowboy
08-17-2000 19:52:50
I'M SURE THAT YOU HAVE DISCUSSED THIS A MILLION TIMES, BUT I'M NEW HERE. I HAVE A 730 THAT STEERS ALMOST OK WHEN IT IS COLD BUT WHEN IT WARMS UP IT IS IMPOSSIBLE TO TURN UNLESS IT IS MOVING AND ALSO IT HAS ABOUT A THIRD OF A TURN OF FREEPLAY IN THE STEERING WHEEL WHICH MAKES IT IMPOSSIBLE TO GO FASTER THAN 5TH GEAR. WHERE DO I START TO CORRECT THESE PROBLEMS AND ABOUT HOW MUCH WILL IT COST ME.THANKS IN ADVANCE
Buckeye al
08-18-2000 13:42:39
 Re: 730 steering problems in reply to plowboy, 08-17-2000 19:52:50
Get a book that describes the adjustment procedure for first the worm gear runout then the steering valve. Don't guess on it, you'll just get frustrated. After you've adjusted these things there MAY be more trouble in the system but your mention of lotsa play says go here first. Let us know what you find.
