JD-LA Is it HAND or ELECTRIC Start???
Obie
08-17-2000 04:59:25
I found a LA I think (there are two rivet holes in the right hand side of housing below seat but no ser. plate) It has 24 inch wheels the owners sez its a 1939 LA...HERE is my question I cant find any starter on it.It has lights and ammeter and a generator however right above the bell housing there is a 5 or 6 inch hole and if I reach in there I can feel the geers on the flywheel,Is this where the starter should go? any advice would be a help tractor look nice good tires all nice tin he wants $1000. for it..What do you think guys??
Dennis Benson
08-17-2000 22:01:37
 Re: JD-LA Is it HAND or ELECTRIC Start??? in reply to Obie, 08-17-2000 04:59:25
Hello,
The price sounds fair. That hole is for the starter. The LA had cast iron centers to the rear wheels, the L had stamped steel rear wheels. There were some less distinctive differences that I can't remember. Those holes below the seat sound like they are for the serial number tag, the absence of the tag lowers the value of the tractor as well as the missing starter, and any damage especially to the sheet metal. You can determine an approximate age by buying the parts manual from the John Deere dealer, about $20.00 if I remember right, and looking up casting numbers that have a year specific change. I've rebuilt several of the John Deere style of the Hercules engine when I worked in an engine rebuilding shop, but not done other work to the tractor. I used a model L in the late 1960's early 1970's.
Tom Smith
09-20-2000 20:11:52
 Re: Re: JD-LA Is it HAND or ELECTRIC Start??? in reply to Dennis Benson, 08-17-2000 22:01:37
They didn't start makeing LA's until 1941. So if it is an LA the earliest it could be is a 41.
