7.50X36 rear tires
durbco
08-16-2000 07:17:33
I have a 1937 B with this size tire. Can these be purchased new(or used)? I talked with Tucker Tire and the closest they can come is 9.50x36.
Is 7.50 correct for this old tractor? If unavailable, will the 9.50's look ok?
It looks like I am going to sink at least $500 in tires for this old machine-is it worth it?
Thanks
Stan Huff
08-17-2000 04:39:08
 Re: 7.50X36 rear tires in reply to durbco, 08-16-2000 07:17:33
According to my Model B Parts Catalog (Publication PC-330, for Serial No. 60000 and up, starting with the 1939 model year), there were several options for tire sizes. The book lists rims for 7.50-36, 9.00-36, 9.00-40, 8-38, 9-38, 10-38, 11-38, 9-42, 10-42, and 11-42 tires. All of these rims are listed for serial numbers beginning at 60000, the first styled tractor - I can only guess if these same rim/tire sizes were available on the unstyled tractors. Maybe someone else can help out?
Stan
Stan Again
08-17-2000 04:43:12
 Re: Re: 7.50X36 rear tires in reply to Stan Huff, 08-17-2000 04:39:08
I'm sure you are aware that tires sizes are identified in different terms these days. The old tire size referred to the rim width (10-38 was a 10" rim) - the same (or close) size tire these days is called an 11.2-38 (approximate), with the 11.2" referring to the overall tire width.
I may be wrong on the exact numbers, but the references are correct, I think.
Stan
durbco
08-18-2000 07:15:22
 Re: Re: Re: 7.50X36 rear tires in reply to Stan Again, 08-17-2000 04:43:12
These rims are about 6 1/2 inches inside. My reference is the John Deere Tractor Data Book by Dunning. If I don't find any new info soon I'll just buy the 9.50's. Thanks for your reply.
ld
