John Deere 730 gas
Mike Quale
08-13-2000 11:51:52
I have a 1959 730 gas and for some reason I can only dyno 51 hp out of it, I have had it dynoed by 3 different dyno's so it cant be the dyno's.... Does anyone know any secrets of how to get more power out of the 2 cylinder gas.....I tractor pull with the 730 in 8500lbs class, and I need more power...I just cant win against big 830's, 820's, Oliver 99's with the big Detroit diesels.....I am kind of the underdog in the class..Is there anything to do to get more power out of the 730 gas
Wind
08-14-2000 14:06:26
 Re: John Deere 730 gas in reply to Mike Quale, 08-13-2000 11:51:52
What, if any, modifications have you made to the engine? Knew of a 52 G that was bored and stroked to 780 cu in. That was pretty extreme. Ended up with about 1/4 inch between sleeves, and stroked far enough that some was added to the sleeves to kep the pistons from tumbling out. Twin carbs and exhaust. Talk about a lugger, never did see that thing run out of power. Traction maybe, but not horses.
Greg H.
08-14-2000 09:53:06
MIke, What size tires are you running?, and what gear do you pull in? Just courious, I've got a friend who uses 18.4x38's, and he pulls in 1st gear and never runs out of power. I think he said he turns around 58 horse power, and when he goes down the track he's able to let off the throttle at times to regain traction, and then it will pick back up again. He pulls very slow, 1st gear. I bet he could start his tractor go to the consession stand get a hot dog, come back, eat it, and be on the tractor for traction control on the end of his pull at about 270 or so. Even with power to spare in first he still will power out in second regardless of if he is pulling the 7500, or the 9,000. Regardless he's got a good tractor, and he's a sentamental favorite. I think he used 104 or 110 octaine gas. Hope you get it worked out. Greg H.
Mike Aylward
08-13-2000 20:41:17
Mike, to be able to help you out we will need to know what you have. What kind of compression pressure are you running? Where do you have your timing set? Have you checked the valve clearance? Is your air cleaner good and clean? Does your 730 have the right carburetor on it (I think it should be a DLTX 95). Let us know what you have and what you have done, and we will go from there. Mike
JD-A man
08-13-2000 20:07:49
have you tried running a higher octane fuel?
is the tractor stock?
you could bore and stroke it and drop some special slugs in it but that cost money .
