3020 gas power
scott
08-12-2000 15:42:09
my 3020 has a cracked manifold. it runs okay, but how much power will this take away from it.
Greg H
08-14-2000 09:40:04
 Re: 3020 gas power in reply to scott , 08-12-2000 15:42:09
If it is an intake, you definately want to get it fixed, because the tractor won't run consistantly well that way. Central Tractor was where I ordered one for my 4020, and the new intake manifold has helped alot, especially in winter usage. If it's an exhaust manifold leak, it may not hurt, unless of course it's back towards the carb, at which case it becomes a fire hazzard. I think my manifold cost around $150 dollars, so if I had the money or could get it, I'd replace the manifold if I were you. I tryed to braze mine first, but for some reason, I couldn't get it to seal real good, and that it why I replaced it. You could try that aswell since you'll have it off anyway. Good Luck. Greg H.
Duke
08-12-2000 20:37:19
Where is the crack? If it is leaking exaust you won't lose power, but it could cause a fire or aphixiation. If the intake is leaking it shouldn't run right,mainly at idle. They have a heat exchanger for heating the intake air in cold weather, there is a diverter for summer or winter operation. I have seen cracks in that area that don't leak when the diverter is in summer position.
