JD60 CARB
BEN
08-12-2000 04:36:27
I just got this 60 running last week. It was a tractor that was underwater during the So tex flood oct 98. I took the carb apart and cleaned it in carb cleaner. the only needle I did not get out was the one on the bottom in the center of the nut it feel froze and I did not want to twist it it off. the tractor runs smooth and clear with the choke pulled half way out. Could this be my problem? and Thanks for the help with the wobble front tires.
Duke
08-12-2000 07:31:28
 Re: JD60 CARB in reply to BEN, 08-12-2000 04:36:27
That is the main jet, it is held in by o rings and threaded. If you can turn it out of the threads you still have to pull it past the orings. The main jet is still availible from Deere. I would say it is likely causing your problems.
