Extra Hydraulic Controls for a 70???
JDGnut
08-11-2000 21:18:44
I am wanting to add a seperate control for my SCV's for my JD70... I am guessing that the only way to do this is to have the oil flow from the pump to the external control valve and then to the factory controls... U have to have the oil flow though the valve and not just tap into the pressure line because it is an open center hydraulic system and must flow through the valve.. (This will hurt the ablility to work both the hitch and SCV at the same time.. but this is not a problem... ) I am wanting to know if there is another way to do this.... Has anyone tried... also am a little worried about ther reservor not being big enough... Any ideas here guys.... JDGnut
STMTS
08-13-2000 10:34:57
 Re: Extra Hydraulic Controls for a 70??? in reply to JDGnut, 08-11-2000 21:18:44
Baker valve is the way to go ,easy to install
Dan King
08-12-2000 23:58:28
Pardon the question, but SCV (solenoid Control Valves/ Steering Control Valves)? What is SCV?
Thanks
JDGnut
08-13-2000 02:18:31
 Re: Re: Extra Hydraulic Controls for a 70??? in reply to Dan King, 08-12-2000 23:58:28
SCV's... selective control valve... Used on a tractor to control hydraulic functions, like cylinder..
JDGnut
Jerry Liverseed
08-12-2000 14:55:27
Try and find a BAKER VALVE thay were a after market hydrualic valve sold back in the 40s
