JD L #7 Mower
Ernie
08-09-2000 19:57:16
Anyone have any instructions on installing a sickle mower on an L ? It came with the tractor I bought yrs. ago, other then trial & error I have no idea. Thanks for your help !!!
John ,,Ne.
08-10-2000 22:15:49
 Re: JD L #7 Mower in reply to Ernie, 08-09-2000 19:57:16
Have had a no.7 on a B for years. try this, back up to the mower, with the mower blocked up level. align the pto shaft with pto on tractor, in line, looking down. The inner shoe on the sickle bar should be about even with the out side of the r.h. rear tire. Then figure out what is needed to attach mower to hitch, have seem a lot of cobbled stuff, if it is tight and allows up and down hinge action of mower, things should be okay. The mower frame should be near level when hitched/bolted on.
John
08-12-2000 14:16:23
 Re: Re: JD L #7 Mower in reply to John ,,Ne., 08-10-2000 22:15:49
John,
The L had only a mid pto shaft, not a rear one. On the L, the mower had to be hung from the tube frame in front of the rear tires, but behind the front ones. The directions you gave appear to be for tractor with a rear pto.
