JD B Clutch Collar(bronze)-Different than Original
Ken Reese
08-09-2000 18:51:59
I replaced a badly worn clutch collar(bronze) on my 1950 JD Model B. The new one has the same number (B172R) as the original but it is a bit different from the original. The difference is:
On the side of the clutch collar that faces toward the main case - and on the collar housing (top and bottom)that accepts the pivot pin -- there are two raised square protrusions (knob) that measure approximately 3/8" high and 5/16 on each of the four sides.
My original has file marks in these areas and it looks as if the knobs have been ground off.
Any ideas on this situation? Why are they on the collar? Why were they ground down? What purpose do they serve, if any? Suggestions?
Thanks for your help.
Ken Reese
E-mail: [email protected]
