70 flywheel
steve
08-06-2000 15:39:35
pardon my ignorance but i have a friend who has a 70 with a splined flywheel which was worn and loose. when he tightened the 2 bolts it ran fine for a while and then cracked. he mentioned $800.00 for a taper lock flywheel. is there anyone who could repair and remachine the cracked unit or is there a cheaper alternative than a new one.
do the splined shafts typically wear or will a new flywheel fix him up.
thank you for your input
bob
08-09-2000 22:16:32
 Re: 70 flywheel in reply to steve, 08-06-2000 15:39:35
you have two alternatives. An $800 taper lock flywheel or replace the crankshaft and flywheel.
I have a 730 diesel that has had a taperlock for over 10 years. works fine.
