620 lift leak down
Chuck
07-31-2000 15:41:25
have a 620 that has a lift leakdown and it will surge while running to keep the lift up.. Have done a lot on tractors but haven't been inside the lift on this model....is the piston oring the problem????? ?
Haybaler
08-01-2000 04:51:36
 Re: 620 lift leak down in reply to Chuck, 07-31-2000 15:41:25
If the lift is the three point hitch it is the oring. Not a real bad job but it is not the easiest either. It is located under the seat and platform. The shop manual will give you the procedure. Don't try 'leak fixer' mixtures they won't work. My 2 bits HB
