JD 2010 diesel with 36A loader
Phil in MS
11-10-2003 06:09:42
Looking at a JD 2010 diesel with a 36A loader. Local dealer said it was worn out and should go for scrap. Asking $2,000. Tractor will crank but requires a good long shot of starting fluid. Sheet metal is in fair condition. No lights just the remains of lights. Rear lift works without any implement attached and hydraluics will lift and lower loader. Loader is tight without any apparent leaks. Will crank and run but smokes.
It would be a gamble but am considering offering $1,500. I have a brother in law that is a equipment mechanic. How hard would parts be to obtain or are parts even available? Any insight would be appreciated. This would not be a primary tractor but I would like to get it straighened out to use as a hay loader and chore type jobs.
Thanks
Run Forest Run !!!!!!
11-10-2003 16:47:36
 Re: JD 2010 diesel with 36A loader in reply to Phil in MS, 11-10-2003 06:09:42
nt
Dan
11-10-2003 06:25:26
The 2010 uses glow plugs to aid starting. If those are working right it should start. Guys either swear by or swear at the 2010 especially the diesel version. In the condition yo are talking about unless the loader is really good I think I would stay away from it.
Phil in MS
11-10-2003 06:44:48
 Re: Re: JD 2010 diesel with 36A loader in reply to Dan, 11-10-2003 06:25:26
Dan,
Thanks for your reply. I have been shopping for a loader for my MF255 for about 4 or 5 months. From what I've seen this loader should easliy go for $1,000 and with a new coat of paint maybe $1,500. I don't think I want to try and adapt it to my MF because you would have to remove the loader to service the battery and other minor things. Have been looking for a QT loader so that in the event of removal I could remove and service and reinstall hopefully on the same day.
Dan
11-10-2003 23:11:50
 Re: Re: Re: JD 2010 diesel with 36A loader in reply to Phil in MS, 11-10-2003 06:44:48
I have a JD 430 with #35 loader. It is a quick detach and with practice it takes about 10 minutes to remove, probably 15 to reinstall. My uncle had the tractor before me and left the loader on all the time. In my area we have corrigations for irrigation and bouncing over those with a loader did a number on the front end of the tractor. It has no power steering. I remove the loader during the summer when I use the tractor for field work and put it on in the fall to plow snow and feed cows. I think the 36 A is a heavier loader than the 35. I'm not that familiar with 36 and how it comes off. The 35 has stands, one on each side and with the hydraulics hooked up you can set it on stands then lift the rear end out of the brackets.. I have quick couplers on hydraulic lines to remove easily. Think the Massy may have better hydraulics than the 2010 as I think they were still the old style pump on the 2010.
