Diesel
Smokin
11-10-2003 05:45:53
What are among the reasons for "wet stacking" in the 2 cylinder diesels? I'm looking at buying one which is otherwise in very good shape except for the fact that it spits wet soot out the exhaust pipe and this stuff gets all over (spots galore). Any ideas about the causes and cures would be greatly appreciated.
Smokin
11-10-2003 16:06:01
 Re: Diesel in reply to Smokin, 11-10-2003 05:45:53
Blksmok and Clooney,
Thanks for your insights and cautions. I'm a devoted fan of the 2 cylinders, but am an admitted mechanical dunderhead.
Blksmok
11-10-2003 07:10:30
The 2 cylinder diesels (70D's) that I've had excessive slobbering on were due to cracked heads or bad head gaskets. They will slobber more on an anti-freeze mix than they will on straight water in the coolant system. I eliminated all of the possible excess/unburned fuel ideas (low compression, bad injectors, injection timing, etc.)first before figuring out the slobber was actually exhaust soot and antifreeze. But, like Clooney indicated there is a long list of other potential causes. All fairly costly to remedy.
Clooney
11-10-2003 06:42:28
Smokin, almost anything that keeps complete combustion from taking place, from....
>low compression
>to low pump pressure
>to worn injectors
>to worn injector tips
>to improper injector timing
>to recessed valves
>to low operating temperature
>to water in the fuel
>to improper cam timing
>to worn cam drive train parts
>to any number of other reasons, or a combination of the above.
~Your problem could be very simple like a water problem, or expensive like a worn out engine.
~If you're lucky maybe it's just stuck rings [I�m never that lucky].
~If it otherwise runs good & starts good in cold weather your slobbering problem will more than likely go away if you work the tractor. If it comes back under light usage then that is a sign of some underlying problem.
~A lot of those 2-cylinder diesels do slobber a little under light usage but I haven't ever had one slobber under any condition if it was in top notch shape.. I have had a few worn ones that slobbered & still operated ok though..
[email protected]
