JD 40 Brush Hog
Dennis
07-26-2000 18:59:35
Model 40 1955 Don't know the HP will this dated machine run a brush hog without damaging the PTO? what size would be the MAX 4 5 6'? Would a slip clutch be necessary? Thanks
Chuck
07-27-2000 11:58:49
 Re: JD 40 Brush Hog in reply to Dennis, 07-26-2000 18:59:35
The transmission on the 40 is not heavy enough to withstand any mishap. If you're determined to use, for all means put the slip clutch on the bushog....don't confuse this with an overiding clutch..two different items...use both...I sold a B to a man recently and he got on a pond bank bottomed out and the jar removed a tooth off the cluster gear...anyway he hired me to fix...$600 and I went by his place and he has the bushog hooked back up just like before...guess he doesn't want to spend the $60 on the slipclutch. The tractor had an override but it didn't prevent the jar back to the gears....think of the bushog as one BIG flywheel and when you jar the thrust into the power shaft....and if you ever went into the 40 transmission you wouldn't use the bushog...the gears look like hen's teeth...but experience is the best teacher...good luck....
Charles
07-27-2000 12:51:38
 Re: Re: JD 40 Brush Hog in reply to Chuck, 07-27-2000 11:58:49
I have a 420T with the 4-speed and transmission driven (not live) PTO. I had bolted my bush hog's slip clutch when it wore out and will be fixing it right away... over the last two years 3rd gear has gotten quite a bit noisier (a moan/whine under load).
Meanwhile I am using it on the 50 which has live PTO. Are there strength concerns with this trans/PTO also?
Chuck
07-27-2000 11:57:19
The transmission on the 40 is not heavy enough to withstand any mishap. If you're determined to use, for all means put the slip clutch on the bushog....don't confuse this with an overiding clutch..two different items...use both...I sold a B to a man recently and he got on a pond bank bottomed out and the jar removed a tooth off the cluster gear...anyway he hired me to fix...$600 and I went by his place and he has the bushog hooked back up just like before...guess he doesn't want to spend the $60 on the slipclutch. The tractor had an override but it didn't prevent the jar back to the gears....think of the bushog as one BIG flywheel and when you jar the thrust into the power shaft....and if you ever went into the 40 transmission you would use the bushog...the gears look like hen's teeth...but experience is the best teacher...good luck....
G Taylor 45 to 48 years old
07-27-2000 09:27:03
You wouldn't take a 1952 to 1955 automobile and use it on the freeway everyday at 70MPH. While hauling a heavy trailer without regularly paying dearly for rair parts while doing a 1/2 baked job at best. The old girls have done their work & earned their keep years ago. You are asking too much of an old small tractor, even a mighty John Deere. Restore it completely and properly with no short cuts ( just bought a 620 with a home brew battery box, seat, wiring harness/charging system, crankcase ventilation etc. Dimwit former owner) , paint it and use it for parades,shows & light clean jobs like raking hay. Enjoy it for years and skip the aggervation.
ToddT
07-27-2000 03:36:59
The Model 40 is about 21-22 HP. I've heard of people running a 5' brush hog, either slowly or only in light brush. An overrunning clutch is a good idea. Otherwise, sometime you are going to try to stop and the momentum of the brush hog blade is going to keep pushing you into whatever it was you didn't want to run into.
The 40's have a weak link in the trans, and that is a cluster gear through which (if I remember correctly) 1st and 3rd grear are driven, as well as the PTO. If you are brush hogging along and hit something, the weakest spot between the engine and the PTO/drivetrain is generally the teeth on this gear. The gear is the last thing that comes out of the trans if you have to dismantle it, and can run a few hundred dollars. (I've been there.) I believe this info also applies to the 320's, 330's and the 420's with 4-speeds and no live power.
ToddT
07-27-2000 13:44:08
 Re: Re: JD 40 Brush Hog in reply to ToddT, 07-27-2000 03:36:59
One more correction, now that I'm home and had the chance to crack open my manuals. The cluster gear is under (drivetrain) load only in 1st and Reverse. It is additionally under load any time the PTO is engaged.
Deere420
07-27-2000 06:19:43
Todd,
I'm curious. Is the 5-speed transmission on a 420 or 430 a stronger transmission and better suited for bushhogging?
Thanks,
Steve
Ray
07-27-2000 17:24:59
 Re: Re: Re: JD 40 Brush Hog in reply to Deere420, 07-27-2000 06:19:43
Just spent $400.00 on 2 used gears for a 430
with live pto. Same trouble just differnt gears.
ToddT
07-27-2000 08:51:23
Well, let me first clarify that I'm not a 420 expert, especially when it comes to the 5-speed trans. I have a 40 (4-speed) that I bought with a broken cluster gear, and I've spent many hours both repairing this and thinking about it. I've also studied both the I&T and JD technical manuals as well as the parts catalogs to determine the path of force through the trans gears.
The problem with this cluster gear is that the engine force is always being pushed through it to the PTO if the PTO is engaged, and is also used for 1st and 2nd gear (correction to my earlier post). This means that while brush-hogging in 1st or 2nd gear, the engine, drive train, and PTO are all in sync with each other, all because of this cluster gear. If any one of these suddenly tries to stop (engine sieze, tractor hits tree, brush-hog hits rock) there is all sorts of torque put on this gear, and it's very likely that some teeth are going to let go.
I was recently reviewing some 420 info in JR Hobb's book "The Little Giants" and there was a mention that the live PTO option on the 420's was a popular option as it greatly reduced the amount of breakdown in the PTO.
Now, thinking about this and looking at the 420 parts manual, this makes sense. With the live PTO, the PTO was no longer driven by coupling to the cluster gear, but by coupling to a new gear introduced for this purpose. This now leaves the cluster gear to serve the drivetrain only, not both the drivetrain and PTO. The load was now spread over more parts in the trans.
The five-speed trans w/o live PTO is very similar in design to the four-speed.
So I think the answer to your question is that the five-speed trans with live PTO is not necessarily stronger than those four- and five-speeds w/o live PTO, but that it is indeed better suited for brush-hogging.
One added note on the non-live-PTO tractors - An overrunning clutch on the PTO will certainly help in the situations where the tractor stops and the brush-hog doesn't. But it won't do any good in the case where the brush-hog stops but the tractor doesn't. You may want to consider adding some sort of shear pin to your PTO drive train. It would be a whole lot cheaper and easier to replace than this cluster gear!
Phil Sutton
07-27-2000 08:29:35
I have a 430 with the 5 speed. I believe you have to have the 5 speed to have live PTO.
It is rated at about 29 h.p. and handles a 5' brush hog with a slip clutch on the pto drive.
Works very good in up to 3" brush. You will have problems tearing up gears without the slip clutch (not overriding clutch) if you get into heavy brush. Been there. The gear costs $350 plus installation awhile back.
Works very well with the slip clutch. You just punch holes in the tires.
ToddT
07-27-2000 08:54:30
 Re: Re: Re: Re: JD 40 Brush Hog in reply to Phil Sutton, 07-27-2000 08:29:35
Phil, I'm hoping to learn something here. I'm not familier with a slip clutch. Could you please explain it a bit? Thanks!
Phil
07-27-2000 10:54:33
 Re: Re: Re: Re: Re: JD 40 Brush Hog in reply to ToddT, 07-27-2000 08:54:30
The PTO shaft has a spring loaded clutch plate next to the gearbox on the brush hog that if the brush hog hits something solid, the pto shaft will slip.
I purchased my brushhog (model 305 bush hog 5') used with it already installed. I guess it's an option. It sure saves on gears.
I have a model 306 6' without this clutch and I do not use it in heavier stuff, even though I have it on a 46 hp tractor.
ZiggyStardust
07-26-2000 19:20:09
Dennis, I would try and find a four foot brush hog. A five foot hog would probably be to much for a 40 in normal conditions.
