620 noise
Chuck
07-23-2000 06:40:47
I've restored several tractors and have been in transmission of many models however am trying to diagnose a sound for a friends tractor. I sold him a 350 JD mower and it works fine mounted on the 620 but at slower rpm there is a distinct clunking. I get it somewhat on my 520 and dismissed it as backlash in the PTO shaft and or drive gears. Has anyone had similar experiences. I don't think there is any gear damage as noise doesn't exist under power up. I also thought it might be worn collars to the powershaft. Any imput appreciated.
Leger
07-24-2000 19:20:38
 Re: 620 noise in reply to Chuck, 07-23-2000 06:40:47
Check your pto shaft and joints, they must be in line and not worn- or they will make the described noise. And it will sound like it is in the transmission.
Leger
07-24-2000 19:19:22
Darryl (MO)
07-24-2000 05:06:17
I got the same thing on my 530 when hooked up to a No. 39N JD sickle mower. It worked fine with a No. 5 mower. If you find out what this is, I'd like to know too!
Ben
07-24-2000 14:30:32
 Re: Re: 620 noise in reply to Darryl (MO), 07-24-2000 05:06:17
My 50 makes a knocking noise when I turn to the left or right, when I have a drag type sreader behind it, Hope someone got the answer.
