Changing freon in 4440
Ray
07-20-2000 19:06:05
Have any of you tried the 134 freon their putting
in the air conditioners now? My 4440 needs to
be charged about twice a year.I've got left over
freon 12 I've been adding,I was just wondering
how hard it was to change over.
Big Jake
07-26-2000 10:01:05
 Re: Changing freon in 4440 in reply to Ray , 07-20-2000 19:06:05
I would also change out the expansion valve. JD
makes on for 134A refrig.
heres another site on off road a/c
link
Steve Young
07-20-2000 19:33:15
you should change the dryer and oil in the compressor but i have seen guys vac it down and install r134a
Andy
07-20-2000 20:26:41
 Re: Re: Changing freon in 4440 in reply to Steve Young, 07-20-2000 19:33:15
Steve, we rarely use any thing else. It is not difficult to use. We convert the charge fittings to 134 and add a 1/2 pint of ester oil to the compressor; then we vacuum at -19, -21 for 25 minutes to boil off water and check for leaks. System must hold vac for 10 minutes with vacuum pump off. Then we simply recharge with the appropriate weight of 134. Tested systems generally work as good or better as previous R12 setups
