420 Ground Speed TOO LOW!
Prune Picker
07-19-2000 10:40:19
OK I have spent numerous hours and $ restoring my '56 420W. I really like this old girl but the thing is SLOW for mowing/brushogging my place. Third gear wound up like a top is around 4 MPH, and fourth gear is out of the question for working the tractor. So, can one install a fourth gear set up (in place of third gear)off a later five speed 420/430, or should I just get used to creeping along?
Charles
07-20-2000 06:47:52
 Re: 420 Ground Speed TOO LOW! in reply to Prune Picker, 07-19-2000 10:40:19
Not sure about the gear swap, but you could just change the whole trans to a 5-speed.
What kind of fields and bushhog do you have that you want to go faster than 4 1/2 mph? My 420T 4-speed usually does the heavy stuff in 2nd gear and (occasionally) some in 3rd. You must have light weeds and smooth ground...
-Charles
Prune Picker
07-20-2000 11:17:39
 Re: Re: 420 Ground Speed TOO LOW! in reply to Charles, 07-20-2000 06:47:52
I use a 5' brushog to mow flat ground lightly covered with seasonal weeds and grass. My last tractor had a ground speed of around 6 MPH which seemed about right. I just don't care to have this old tractor wound for sound all the time in working it. Thanks for your response.
jd puller
07-20-2000 09:53:52
old tractors were mnot made to go fast. they are geared to there hp. if you want to go faster get a biger tractor but i think yer crazy for wanting to go fast while working the tractor. you could end up braking something or hurting your self.
G Taylor mower works better at 540 RPM
07-20-2000 14:41:32
 Re: Re: Re: 420 Ground Speed TOO LOW! in reply to jd puller , 07-20-2000 09:53:52
A flail mower works better at rated RPM as centrifical force holds the blades out straight. Why not trade for a tractor with the five speed AND live PTO. Farmers here lined up for those options when they became avalable after serial #100,000 on 420's. Transmission PTO a hinderance. Could just mow in 3rd ,what is the hurry? Enjoy the two cylinder sound.
