John Deere 50 questions
Kerry Miller
07-17-2000 20:05:03
How many HP is a 50 John Deere? We had one when I was a kid, I'm thinking about 40 but not sure. I found one on LP here locally, is there anything that is a common problem to watch for?
Tnx,
Kerry Miller
Cumby, TX
trnut
07-17-2000 21:17:14
 Re: John Deere 50 questions in reply to Kerry Miller, 07-17-2000 20:05:03
Book says 30.97 belt, 27.49 drawbar, on gas--All-fuel is about 4-5 hp less on each number. LP seems as if it would fall between the 2, toward the lower end, as there is less energy in LP than gas. BTW, I have a 50 and really like it!
Kerry Miller
07-18-2000 20:13:55
 Re: Re: John Deere 50 questions in reply to trnut, 07-17-2000 21:17:14
Humm, I thought it was more, but I was a kid a long time ago... Do you guys know approx. how much it weighs? I think I've talked myself into it if I can get it home. The sheet metal is all there and is in good shape, just a gash in the left screen about 2" long, so it's a pretty good prospect for a restoration. In the mean time I can mow and disc with it.
Tnx,
Kerry
Kerry Miller
07-18-2000 20:52:14
 Re: Re: Re: John Deere 50 questions in reply to Kerry Miller, 07-18-2000 20:13:55
Here's another question. I used to have a 1952 A with a homebrew 3-point and I'd like to try the same on this JD50. Does anybody know how to hook up a top link? Or, are there any pictures or drawings around?
Tnx,
Kerry
Fudd@Work
07-17-2000 21:51:07
I have a 50 also and really like it. I mount a 9W mower on it and it makes a great mowing machine.
Kerry Miller@work
07-20-2000 12:05:37
 Re: Re: Re: John Deere 50 questions in reply to Fudd@Work, 07-17-2000 21:51:07
Ok, I think I've talked myself into it. I'm going to look at it again tonight, I want to load it up and see how it runs under load. He was using it on a manure spreader last time so I couldn't do anything with it but hear it run. If it still runs ok, I'll probably pick it up this weekend.
I've used one before but it's been almost 30 yrs. I had an A a couple of yrs ago but it's not quite as good as the 50 and didn't have power steering.
Thanks for all the replies!
Kerry
