JD 70 gas shutoff
Dave 2N
07-17-2000 04:04:16
Need some help from you 2-banger guys-
What's the best way to deal with the automatic fuel shutoff on a 70 gas? I've heard rebuild it and I've heard replace it with one with a manual shutoff. Which way should I go? I assume the failure of the shutoff to work properly was the reason that I picked up about 6 gallons of gas in the crankcase at a county fair show and pull. Drained the crank case into pails and replaced the oil but don't want to go through that anymore. Float specs seem to check out. Shouldn't the float have prevented this? Any other suggestions? Thanks!!
DP
07-17-2000 04:18:53
 Re: JD 70 gas shutoff in reply to Dave 2N, 07-17-2000 04:04:16
Dave, the gas entered your crankcase through the oil pressure line that supplies pressure to turn the gas on. It is simple to fix. Remove the automatic shutoff from the tracor and replace the two little rubber diaphrams in it. I have three tractors with this setup, and once these are replaced, they work fine. The purpose of this system is to shut the tractor down if the oil pressure is lost. Good luck Don
zane
07-18-2000 17:52:18
 Re: Re: JD 70 gas shutoff in reply to DP, 07-17-2000 04:18:53
I'm sure you're right about the fuel being able to enter the crankcase through the oil pressure line. Also, JD probably asserted that the purpose of the device was to protect the engine against oil pressure loss. But--I've seen the fuel tank drain into the case more than once on 50's and 60's through the carb--the float hangs. I know it was through the carb because the oil-operated cut-off was not installed. I suspect this is the real reason JD started using the cut-offs.
Dave 2N
07-19-2000 04:20:49
 Re: Re: Re: JD 70 gas shutoff in reply to zane, 07-18-2000 17:52:18
We repalced the diaphragms and everything works now. There was gas in the one oil line when we took it apart. Carb was just rebuilt and re-checked. We made sure no gas was going to the carb. for awhile and then when we took the oil lines loose, that's when we discovered gas in the one line. Anyway, so far so good.
Dave2N
07-17-2000 06:09:33
Don-
Thanks-I see now and have the parts ordered.
Dave 2N (another DP)
