Tuning a JD 318 carb
John Elk
07-15-2000 21:02:57
Can anyone out there give me some tips on tuning a 318 carb? Also, how to identify the fast and slow speed idle adjustment
Steevereno
07-17-2000 19:33:11
 Re: tuning a JD 318 carb in reply to John Elk, 07-15-2000 21:02:57
To adjust the slow idle speed theres a screw on the right side of the carb (if your in the seat). It is hooked up to the governor linkage. The slow idle fuel mixture screw is facing the front down near the bottom of the carb. To adjust the fast idle speed look where the throttle cable hook to the engine. You should see a lever with a spring on it with a series of hole drilled into it and the govenor arm. Moving the spring into varios hole will increase or decrease the speed. The tighter the spring the higher the RPM. Hope this helps.
