Electrolysis mixture question
Brandon
11-09-2003 19:34:03
I'm about ready to convert to the electrolysis religion, but I need to know if I need to worry about the mixture freezing. With temps now in the 20s, freezing is definitely a possibility.
I can't remember enough of the rules about solutions (moles, etc) to know if the lye will lower the freezing point in any way or not. I doubt it.
I'm planning on cooking some Oliver parts. Electrolysis will work on those too, and not just JD parts, correct? Heh, heh.
Thanks,
Brandon
My Industrial John Deere website
My JD model 80 website
The LaGrange Engine Club
F-I-T
11-09-2003 21:36:53
 Re: Electrolysis mixture question in reply to Brandon, 11-09-2003 19:34:03
Brandon:
I'll have to do some research, but I seem to remember that Sodium Hydroxide in a 20% aqueous solution will freeze at about 14*F, but as you go stronger the freezing point rises A LOT, to the point that 50% solutions can begin to freeze at like 60*F. It's very weird like that.
I don't have anything on Sodium Carbonate, so I might have to set up some experiments in my freezer. I'm guessing it will act alot like salt water.
Now, if you want to work in lower temps, use as strong a solution as you can to make the current draw as high as you can get it, and always leave the power on. If you run out of parts, put a piece of scrap or a spare electrode in to be the part to be cleaned. Those watts will warm the water. 12V x 5 amps or better will probably keep the tank liquid. You can also toss a few half filled two liter bottles in there so if ice forms the bottle will absorb the expanding ice front (like an inner tube in an Ohio swimming pool).
I've not tried Oliver parts. It is possible that you might begin a chain reaction leading to the end of life as we know it.
But then again, if you've run out of JD's to work on and you're down to Ollies....what do you have to live for anyway?
Phasers on stun, Good luck, Kirk out.
F-I-T
Ralph
11-09-2003 21:33:40
Lye has the same effect as sodium chloride on the freezing point. Some substances have a rather large temperature coefficient of solubility. That is they drop out of solution as the temperature drops. The Handbook of Chemistry and Physics at least used to include these tables. The depression of the freezing point depends on the amount dissolved, I expect you are working with dilute solutions, therefore the freezing point depression is limited.
