JB Weld
Big Swede
07-12-2000 08:07:07
Has anyone successfully used JB Weld between the head and exhaust manifold on a two cylinder tractor? Head is erroded on exhaust port on #2 side. It's too much to expect gasket to take care of. Thanks in advance for any comments or ideas.
Mike (MI)
07-12-2000 14:08:29
 Re: JB Weld in reply to Big Swede, 07-12-2000 08:07:07
I've used JB on an Allis about 5 years ago and it is still holding. It depends on how thick it is. If it is filling a gap that is less than .050" or so, it will work great. Much more than that, and it can't transfer the heat back to the head quick enough. JB guarantees their epoxy up to 600 degF. Exhaust temps are much higher than that, but the cylinder head is not. The surface it is applied to has to be rust and oil free. I made a masking tape "moat" on the head. Then I put a sufficient amout in there and let it cure. A long, wide flat file and about a half hour later, the manifold went back on - for good, so far! I'd like to see the Fire Stick stuff...
Jim
07-12-2000 11:06:06
I tryed it on a WD Allis .We plained the manifold off smooth ,cleaned the head up . It lasted maybe 5 minutes at the most .
Haybaler
07-12-2000 10:23:15
I didn't think it (JB) would hold either but I have a 730 that was eroded on #2 side. Mixed up the compound, filled in the gap, set the gasket on top of the compound while it was still wet and torqued it down. Started the tractor after 30 minutes and let it run just long enough to get warm and let it set overnite. Did this over 5 years ago and it is still holding. This is a working 730 that pulls a 13 ft disk and a 15 ft field cultivator on a 40 acre farm and it gets cherry red. My 2 bits. HB
Bama Dee
07-12-2000 09:43:06
If sealing the eroded face is the only problem, use Hilti fire chalk ( good for 1000F will expand slightly) cost 7-10$ a tube, good stuff-I've used on fire wall construction for years Good luck
Haybaler
07-12-2000 10:24:12
 Re: Re: JB Weld in reply to Bama Dee, 07-12-2000 09:43:06
Hey Bama where can you get the compound you were talking about? Thanx. HB
Marky
07-12-2000 20:12:13
 Re: Re: Re: JB Weld in reply to Haybaler, 07-12-2000 10:24:12
Check out the P.O.R.15 Restoration for exhaust manifolds. The stuff is call Fireseal. Works great. I used all there stuff and it really stopped all the rust and put a hard coating on top. Just don't get it on your hands it won't come off.
Bama Dee
07-12-2000 08:37:25
I've used both JB Weld and Marine Tex on the head, but not at the exhaust port! I don't think either material will stand up to the heat. Can you cut down a GM exhaust donut and fill the gap?
