Its ALIVE!!! but a little noisy??
Denny Foster
11-09-2003 18:23:35
Well got my 1940 H running today after a total rebuild, runs excellent but the governer seems a little noisy, I have a B also and it is noisy too. I am wondering if I am making too much out of it but I set the gears up on the fanshaft to run pretty deep, like I do for automobile rear ends but they run submerged in 90 weight gear oil and of course the fan shaft gets sprayed with engine oil. What is you guys take on this??
Denny
Clooney
11-10-2003 04:13:24
 Re: Its ALIVE!!! but a little noisy?? in reply to Denny Foster, 11-09-2003 18:23:35
Denny, give those governors some time.. Anytime you disturb the running position of those fan gears you will have noise for a while.. In time the noise will subside, how much? Only time will tell..
~When setting those gears up just line the heels up, then set the back lash.. If there are any burrs on the ends of the gears [very common] use a stone to remove the burrs.. Those burrs are what usually cause the noise...
[email protected]
Denny Foster
11-10-2003 17:04:41
 Re: Re: Its ALIVE!!! but a little noisy?? in reply to Clooney , 11-10-2003 04:13:24
Thanks for the help Clooney, I ran it a bit more today and it seems quieter but it could be my tired ears!!!
Denny
