3 point hitch
wes
11-09-2003 18:02:26
I've been looking for a 3 point hitch for a 70 JD, I beleive it's an 800 seris hitch not really sure, any suggestion where I should look.
JDVan
11-09-2003 19:48:30
 Re: 3 point hitch in reply to wes, 11-09-2003 18:02:26
Wes:
They do show up on eBay occasionally but be very careful about their condition and completeness. Quite often the Chains, Evener Bar and in some cases even the two top links are missing. Also check for damaged draft arms. There are 3 different versions of the 800 Series Hitch. All compatible with the JD 70. Properly taken care of and when complete make a very good hitch for work and play. There are aftermarket suppliers who sell reproduction Chains, Clevises, Evener Bars and Centering bars. JD still sells some of the minor parts. Get your hands on a Parts Catalog (PC397) so you know what all is included in each version of the hitch. The 800 was made from 1953 to 1955, The 800a in 1955 and then the 801 was made from 1955 on.
Good Luck.
F-I-T
11-09-2003 21:39:36
 Re: Re: 3 point hitch in reply to JDVan, 11-09-2003 19:48:30
JDVan:
What "minor parts" does JD still offer? I really need some of the correct pins that hook things together. Bolts sort of look out of place.
Frank
Putt Putt
11-09-2003 22:05:26
 Re: Re: Re: 3 point hitch in reply to F-I-T, 11-09-2003 21:39:36
Hi Frank---
Hope you're getting free of that flu bug.
I got several of the pins for my 801 hitch from John Deere a couple of years ago. They are, no doubt supercedes but look authentic.
I have the parts catalogue if you need a look up.
Putt Putt
F-I-T
11-10-2003 08:02:31
 Re: Re: Re: Re: 3 point hitch in reply to Putt Putt, 11-09-2003 22:05:26
Putt:
Flu is pretty much goine. Just enough to mess up my weekend!
If those pins look good to yu, I might just order some. I need, you know, 5 or 6. I just thought if they're still available, now's the time to finish it out.
Thanks, but I already have the parts book.
Frank
JDVan
11-09-2003 22:02:54
Frank:
Are you going to go to the GOG 2004? I'm giving a session on 800 hitches there. Do you have a PC 397?
JD still sells OR tries to sell at these prices:
45M7030 - $3.45
RV695A - $4.65
RV741A - 45.50
RV805A - $5.50
RV806A - $4.95
F-I-T
11-10-2003 07:49:53
 Re: Re: Re: Re: 3 point hitch in reply to JDVan, 11-09-2003 22:02:54
JDVan:
~~Do you have a PC 397?
Yes, I do. I'll high light the parts you list in my book.
Thank you!
Frank
JDVan
11-09-2003 22:04:26
Frank: A typo. I'll try again
45M7030 - $3.45
RV695A - $4.65
RV741A - $5.50
RV805A - $5.50
RV806A - $4.95
F-I-T
11-10-2003 07:59:33
 Re: Re: Re: Re: Re: 3 point hitch in reply to JDVan, 11-09-2003 22:04:26
Van:
I looked all the way through the parts book and can't find the 45M7030.
What is that?
Frank
JDVan
11-10-2003 08:19:57
 Re: Re: Re: Re: Re: Re: 3 point hitch in reply to F-I-T, 11-10-2003 07:59:33
Frank:
Sorry, that is the current number and metric equivalent for 14779A, the drawbar/clevis pin. That is all JD sells anymore. It seems longer than what it should be but I don't have an original 14779A to compare it to.
