B front wheel wobble
JL
11-09-2003 17:41:14
Have an early styled B with a bad front end wobble. We tightened the wheel bearings. Nothing changed. So we opened up the covers on top the shaft hoping we could get it out by adjusting the bushing and gears. We had the front end jacked up, and with the top cover off we could see that the wheels could be moved, moved lots too much, and the gears up top werent moving at all. So what is worn out? Where do I look? I have an I/T book but I cant hardly tell from that. It tells me to adjust the gears. Thanks for the help.
Clooney
11-10-2003 06:50:50
 Re: B front wheel wobble in reply to JL, 11-09-2003 17:41:14
JL, two possible places..
~The first is at the top shaft splines where it enters the sector gear,, Look closely at the shaft to gear mating place while someone moves the front wheels.. Any play there is not good.. Maybe just tightening the gear nut will help.. If not pull the gear off & look for spline wear on the shaft & gear..
~The other place is at the bottom of the steering shaft where it enters the lower spindle casting [especially if you have a Roll-O-Matic.. Look for movement at the shaft to lower casting & look for loose rivets..
[email protected]
Larry E
11-09-2003 17:53:02
Do what the book says and it will work.
