4020 top link
David Jones
11-09-2003 16:54:26
I have a 72' JD 4000. It didn't come with a top link. Do I need one of these ones with the hook looking end or will an ordinary one work? Was the one with the hook for the early model new generation tractors?
Glen in TX
11-10-2003 15:18:29
 Re: 4020 top link in reply to David Jones, 11-09-2003 16:54:26
Some aftermarket ones out there with hook end to use with balls for those models, early one was different. Can always make adapter plates out from top to get balls and hook to fit or clear and screw in top link some. Bolt or weld the plates on. Many companies did this on their hitches later and we did ours to get quick hitches to fit.
JW
11-09-2003 19:02:30
I think you would need the hook ended link, depending on the size of your implements (cat1 or cat2) you could get a regular link and do just a little grinding to fit it into the link reciever on the tractor. The cat1 links will work like that, the cat2 links are too thick to grind and still hold weight. I ground a link to fit my 4010 cause some of my implements would not take the claw end.
Pete/ME
11-10-2003 03:27:49
 Re: Re: 4020 top link in reply to JW, 11-09-2003 19:02:30
I got some of those ball things to adapt my implements. Just slide the implement top pin through the ball.
JW
11-10-2003 08:57:42
 Re: Re: Re: 4020 top link in reply to Pete/ME, 11-10-2003 03:27:49
Just because the ball fits the implement won't insure the claw will fit. Some of the top link recievers on the implement do not allow enough room for the claw to fit. There is alot of bulk on the back side of the claw and you might have a problem with clearance on some implements (especially the ones that do not have an open top reciever such as some scoops, blades, spraytanks).
