Late Styled JD A Brake Sticking.
Big Buck
07-02-2000 19:44:11
One brake pedal on my JD "A" will not release unless I pull back on the pedal with my hand. Is there a spring missing or broken that would be an easy fix or is it a major deal?
JDBob
07-03-2000 10:08:23
 Re: Late Styled JD A Brake Sticking. in reply to Big Buck, 07-02-2000 19:44:11
There are two springs in the A's brakes. Like Fudd said, you should be able to take the assy. out and give it a real good cleaning and and get the rust out of everything.
The brakes aren't REAL bad to get apart and work on but they sure aren't my favorite thing to fool with either.
I'd try shooting some good penetrating oil around the the shaft the brake pedal attaches to, and maybe a little down in the oiler on the top back side of the brake assy.
Just my 2 cents.
JDBob
Haybaler
07-06-2000 10:12:25
 Re: Re: Late Styled JD A Brake Sticking. in reply to JDBob, 07-03-2000 10:08:23
Hey JD Bob. I thought they were supposed to be that way, you mean they're not!!
Fudd
07-02-2000 20:16:50
My 50 did that when I bought it. You should be able to remove the brake assembly by removing the three bolts that hold it to the transmission. The shaft the brake pedal is mounted on is probably rusted. I had to remove the pedal shaft and clean it up along with the bore it goes in. I greased it all good before reassembly and haven't had any problems since. Good luck.
dave k
07-06-2000 14:26:54
 Re: Re: Late Styled JD A Brake Sticking. in reply to Fudd, 07-02-2000 20:16:50
There are three bolts holding each brake assembly on. I found them easy enough to work with.
dave
