420 W Hydraulic help or parts
Ken
07-02-2000 10:26:38
I have trouble with the dual touch-o-matic hydraulic system. When I bought the tractor, the hydraulics were only half there. I think I have all the parts how but I put it together and only the inside arms lifts and drops immediately after stopping engine. I'm looking for some-one to work on it or I would consider a whole different system. I'm ready to use it as a Forth of July fire-works display. My local JD Dearler is not interested in fixing it. Located in Central Wi.
Devon Hubbard
07-06-2000 18:34:32
 Re: 420 W Hydraulic help or parts in reply to Ken, 07-02-2000 10:26:38
I just finished overhauling the dual hydraulics on my 420 W. It was having basically the same problem, the outer lift arms would work (barely) but the inner wouldn't move. Turns out a roll pin came loose inside which disconnected a linkage that rendered it useless. The rollpin was chewed up by the pump and caused all kinds of scoring in the cylinder walls. However, it was not to tough to fix and works better now than it ever did during the 20 years I have owned it. The system leaking off could be caused by any one or combination of several things.
Bryan Shippy
07-02-2000 15:53:16
Hey Ken if this is any consulation i am having a simliar problem with my 420w i do have a manul from john deere my guess would be you may have a check valve problem if you need to see a picture of my hydrulic system that i sure is complete give me a call at (785)869-2977 I am located in Ks
