J.D. 50 right main bearing
ben
06-30-2000 17:52:37
On a 50 can the two oil seals be removed without pulling the main ? I have the frist seal out, Now the next one is the one I need to know about.
Rob
07-03-2000 17:05:24
 Re: J.D. 50 right main bearing in reply to ben, 06-30-2000 17:52:37
I suppose it could be done, but you wouldn't know for sure that you had it installed correctly when you are done. If you have it apart far enough to remove the outer seal, why not pull the main? All you have to do is unhook the oil line to the bearing (it's cramped, but it can be done) and then everything is out in the open. Good luck!
