50 choke
don
06-29-2000 17:31:40
Freinds 50 the choke was apart there is a spring & cover & bolt to hold the cover the spring has a hook on one end & staight bend on the other end. Is there something missing? The pin that goes thourgh the shaft if it is across is that open it always seem to be half off. Either to much choke or not enought How does it go toge
Chuck
06-30-2000 09:49:12
 Re: 50 choke in reply to don, 06-29-2000 17:31:40
kinda hard to explain, but the spring pulls the choke on and this allows the suction from the engine to pull it off when it starts. You have to preload the spring when you put the cover on. It'll be simple when you figure out.
don
06-30-2000 17:53:57
 Re: Re: 50 choke in reply to Chuck, 06-30-2000 09:49:12
Thanks was able to figure it out when I got by myslef it was eas
