Open/Closed hydraulic system on a 430 and a 4010?
Jim
06-29-2000 15:41:05
I want to take a back hoe off a 430 and put it on a 4010. Does the 430 and 4010 have the same type (open or closed) hydraulic system or will I have to change the back hoe valves?
STMTS
06-29-2000 17:45:26
 Re: Open/Closed hydraulic system on a 430 and a 4010? in reply to Jim, 06-29-2000 15:41:05
The 430 has a open center,the 4010 has closed center,But if you would hook up the backhoe to the 4010 remote coupler and tie the handle in the raise position it will work fine,also there is one thing to think about is the 430 has around 1250psi and the 4010 has around 2350psi. You need to be sure that the backhoe system will stand the pressure difference. Mike
